TL;DR: Project tracking compares actual progress against your plan to catch delays early. Choose pre-built options like Monday.com (visual boards), Asana (task dependencies), Jira (Agile development), or Smartsheet (spreadsheet-style), or build a custom tracker with Bubble’s AI generation and visual editing. Essential features include plan vs. actual tracking, milestone management, visual workflows, automation, and mobile access. The best choice depends on your team’s working style rather than feature count.
Most project delays don’t announce themselves. Instead, they accumulate quietly. A task takes three days instead of two, a dependency isn’t tracked, a resource conflict isn’t noticed until it blocks critical work. By the time the problem becomes obvious, you’ve lost the window to fix it without affecting your deadline or budget.
The real problem isn’t your team’s effort; it’s information gaps. Spreadsheets go stale the moment someone can’t update them immediately. Email threads bury blockers. Status meetings are rated the #1 wasteful meeting type by employees because they often waste hours rehashing old news. Without real-time visibility, you’re deciding with old data and catching delays too late.
This guide covers six pre-built project tracking tools — plus Bubble, the only platform where you can build a custom tracker with AI generation and visual editing that matches your exact workflow without code. You’ll learn what features actually matter, how each tool handles different workflows, and which option fits your team’s size and process. We’ve included a comparison table and selection guide so you can pick the right tracker and get back to building.
What to consider when choosing a project tracker
Project tracking is the process of monitoring how your actual progress compares to your original plan. You set goals, break them into milestones, and use visual tools to see whether you’re ahead, on track, or falling behind. This information is critical, given PMI’s finding that only 50% of projects succeed globally.
The right tracker makes this automatic instead of requiring constant manual updates, which can free up your team to focus on more important work. A Wrike survey found 45% of PMs spend a day weekly on manual status reporting alone.
When evaluating pre-built tools, start with these must-have features.
- Plan vs. actual tracking shows the gap between where you planned to be and where you actually are
- Milestone management breaks large projects into smaller checkpoints so you catch delays early
- Visual workflow displays like Gantt charts or Kanban boards help teams understand complex projects at a glance
- Automation updates task status automatically when team members mark work complete
- Mobile access lets field teams update progress from job sites without switching devices
Nice-to-have features for pre-built tools include advanced dashboards, API access, and audit trails, but they’re often locked behind higher-tier plans or sold as separate add-ons. With Bubble, these aren’t upgrades you pay extra for. You can build them with the Bubble AI Agent (beta) in minutes and connect any external integrations with the API Connector.
The 7 best project progress tracking tools for teams
The best tracker is one your team actually uses. A tool with every feature won’t help if your team finds it confusing. A simple tool won’t help if it forces you to work around its limitations instead of supporting your actual process.
We evaluated pre-built tools on automation strength, visual clarity, and workflow flexibility. Bubble is different: Instead of selecting from a list of features, you build exactly what you need with AI generation and visual editing. The choice comes down to whether you want fast setup with pre-built features or you prefer to customize.
1. Bubble: Best for building a custom tracker you can see and control
When off-the-shelf trackers force your team to work around their limitations, Bubble lets you build exactly what you need. You can generate a working tracker in minutes with AI. Visual workflows display every automation in natural language so you can understand and modify each step without technical expertise. Unlike AI coding tools that generate code you can’t read, Bubble’s visual editor lets you fix issues yourself and iterate with confidence.
As your process evolves, you can chat with the Agent or adjust workflows directly in the visual editor. The AI Agent can generate native mobile apps that share your web app’s backend, so field teams can update from job sites while office teams see real-time data. The Agent also creates privacy rules automatically, ensuring that team members see only their tasks while managers get the full picture. You can describe what data you need, and it builds custom fields and database structure on the spot.
Best for:
- Agencies wanting to deliver client project tracking 10x faster. You can generate working trackers fast with AI, then use visual editing to match your client’s branding and approval workflows exactly
- Operations teams needing project approval processes that match company policies exactly. See and control every approval step in visual workflows, not code, so compliance teams can verify the logic themselves.
- Companies wanting mobile field progress updates. Build native iOS and Android apps with AI that let field teams update project status from job sites, sharing the same backend as your web dashboard.
- Teams who want AI speed without getting stuck with code they can’t read. Vibe code without the code to build the exact project tracker you need, with full visual control over every detail of your workflow.
Limitations: Generates quickly with AI, but when you want deeper customization beyond what AI provides, you’ll invest time using visual editing to build exactly what you need. (This is still much faster than traditional AI coding tools that leave you mired down in code if you want to refine.)
Pricing: Free plan available ($0), Starter at $29/month (billed annually), Growth at $119/month (billed annually), Team at $349/month (billed annually), Enterprise (custom pricing). Plans include workload units that scale with usage (Free: 50K WU/mo, Starter: 175K WU/mo, Growth: 250K WU/mo, Team: 500K WU/mo), with overage charges of $0.30 per 1,000 workload units on paid plans. File storage varies by plan (Free: 0.5GB, Starter: 50GB, Growth: 100GB, Team/Enterprise: 1TB).
Compare to: AI coding tools (Lovable, Bolt, Replit) when you want AI speed without getting stuck with code you can’t read. Compare to Monday, Smartsheet, ClickUp when template limitations block your exact workflow.
2. Monday.com. Best for visual teams wanting quick setup and automations
Monday.com uses color-coded boards that make your project status clear. You can drag tasks between columns and update progress with dropdown menus. The interface prioritizes visual clarity over text-heavy lists, making it popular with marketing teams and small businesses.
The timeline view displays tasks as a visual schedule for identifying deadline conflicts. Workload management displays team capacity and allocation. The automation library provides pre-built recipes for common workflows, such as notifying stakeholders and updating dashboards when tasks move to “Done.”
You can start with simple boards and add complexity as your team adopts the platform. Multiple view options (calendar, timeline, map, chart) let different team members work the way they think.
Best for:
- Marketing teams managing campaigns with many moving parts
- Small businesses needing quick deployment without technical setup
- Teams that prefer visual boards over text-based task managers
- Organizations wanting pre-built automations instead of building workflows from scratch
Limitations: Advanced features require higher-tier plans, and costs increase quickly as you add users and automations. Automation action limits are 250 actions/month on Standard, 25,000 actions/month on Pro, and 250,000 actions/month on Enterprise.
Pricing: Free plan available ($0 for up to 2 seats), Basic plan at $9 per user monthly when billed annually, Standard at $12 per user monthly, Pro at $19 per user monthly, and Enterprise tier (contact sales for pricing).
Compare to: Asana, Trello for visual project management with less customization needed.
3. Asana: Best for collaborative task tracking and team coordination
Asana organizes work around tasks as the primary unit. The platform supports project creation, task assignment, due dates, and subtasks for breaking down larger work items. Task dependencies show which work is blocked and which can proceed.
Custom fields allow teams to add project-specific data beyond the default task structure. The timeline view displays task connections and how changes to one task’s schedule affect others. Workload tracking shows task distribution across team members.
The platform includes collaboration features that attach discussions directly to tasks. Users can comment on tasks, attach files, and follow tasks for updates without being assigned to them. HIPAA compliance is available on the Enterprise+ plan through a Business Associate Addendum.
Best for:
- Cross-functional teams managing multiple interconnected projects
- Companies needing strong task dependency tracking for complex workflows
- Teams transitioning from basic to-do lists who need more structure
- Organizations wanting built-in collaboration features instead of adding external chat tools
Limitations: Advanced features like portfolios and workload management require paid plans; the interface can feel overwhelming for simple projects.
Pricing: Personal plan free for up to 2 users, Starter at $10.99 per user monthly (billed annually) or $13.49 (billed monthly), Advanced at $24.99 per user monthly (billed annually) or $30.49 (billed monthly), Enterprise and Enterprise+ (contact sales for pricing).
Compare to: Monday, Wrike for team collaboration focus with less visual emphasis.
4. Wrike: Best for analytics-heavy teams and enterprise requirements
Wrike provides an analytics-heavy approach to project tracking. The platform includes custom dashboards that aggregate data from multiple projects, displaying resource allocation, budget status, and timeline informationin one view. Reporting capabilities track metrics like team velocity and workflow bottlenecks for identifying patterns and process improvements.
The resource management features allow teams to distribute work across members and monitor billable hours relative to project budgets. Workflows can be configured to match organizational processes, including approval stages and handoff points.
Wrike supports multi-project portfolios with shared resources across teams. The platform integrates with enterprise systems including Salesforce and Tableau. Wrike holds TX-RAMP Level 1 certification alongside SOC 2 Type II and ISO certifications.
Best for:
- Teams needing detailed analytics on resource utilization
- Agencies managing client work with budget tracking and profitability reporting
- Organizations requiring enterprise security, SSO, and compliance features
- Teams wanting to analyze project patterns and improve processes over time
Limitations: Steep learning curve for new users; expensive for small teams who don’t need advanced analytics.
Pricing: Free plan available ($0), Team plan at $10 per user monthly (billed annually, 2–15 users), Business at $25 per user monthly (billed annually, 5–200 users), with Pinnacle and Apex tiers available (contact sales for pricing). Pricing valid for purchases on or after January 21, 2026. Automation limits are plan-dependent: Team plans include 50 actions per seat monthly, Business includes 200, Pinnacle includes 1,500, and Apex includes 3,000. Additional automation packages can be purchased separately.
Compare to: Smartsheet, Microsoft Project for enterprise-level project management and reporting.
5. Jira: Best for software teams using Agile methodologies
Jira focuses on software development workflows. The platform includes sprint planning tools for committing to work, tracking daily progress, and adjusting scope. Burndown charts show whether committed work will finish by sprint end. Epic tracking links large features to their component stories and tasks.
The platform integrates with developer tools like GitHub and Bitbucket, connecting code commits to tasks. Issue tracking captures bugs, tracks severity levels, and routes them through QA processes.
Workflows can be configured to match different development processes, including Scrum, Kanban, or hybrid approaches. Reporting features include velocity charts and sprint reports for tracking team performance over time.
Best for:
- Software development teams using Scrum, Kanban, or other Agile methodologies
- Organizations needing issue tracking integrated with project management
- Teams wanting developer tool integrations for seamless workflow
- Companies managing product backlogs and release planning alongside sprint work
Limitations: Complex for non-technical teams; primarily designed for software projects, less suitable for marketing or operations work.
Pricing: Free for up to 10 users, Standard at $7.91 per user monthly, Premium at $14.54 per user monthly, Enterprise tier available (billed annually, contact sales for pricing). Annual billing available with up to 17% savings. Automation limits vary by plan: Standard: 1,700 rule runs/month shared among all users, Premium: 1,000 rule runs/month per user, Enterprise: unlimited automation. Storage limits: Standard: 250GB, Premium/Enterprise: Unlimited. Uptime SLA — Premium: 99.9%, Enterprise: 99.95%.
Compare to: Azure DevOps, Linear for Agile software development with different interface approaches.
6. Smartsheet: Best for spreadsheet-native teams with complex dependencies
Smartsheet uses a spreadsheet-style interface with added project management capabilities. Teams familiar with Excel or Google Sheets can work within a grid structure while accessing automated workflows and dashboard features. The row-and-column format reduces the learning curve for users accustomed to spreadsheet tools.
Automated workflows execute actions when cell values change — for example, sending alerts when a date column indicates an overdue task. The Pro plan includes 250 automated triggers per month; Business, Enterprise, and Advanced Work Management plans offer unlimited automations. Resource management displays assignments across sheets for identifying scheduling conflicts. Portfolio dashboards aggregate data from multiple sheets into consolidated views.
The platform supports task dependencies through formulas and cell linking. Forms enable data collection from stakeholders without requiring direct sheet access. Card view converts rows into Kanban-style cards for teams preferring visual task organization over grid layouts.
Smartsheet Gov holds FedRAMP Moderate ATO and DoD Impact Level 4 (IL-4) Provisional Authorization for government and defense sector requirements.
Best for:
- Teams comfortable with spreadsheet interfaces who want to add project management features
- Projects with complex task dependencies and timing requirements
- Organizations needing detailed resource planning across multiple projects
- Companies wanting to maintain spreadsheet familiarity while gaining automation
Limitations: Storage limits vary by plan (Pro: 20GB, Business: 1TB, Enterprise: Unlimited) with attachment size restrictions (Pro: 30MB max, Business+: 250MB max); consider storage needs as data volumes grow.
Pricing: Pro plan at $9 per user monthly (billed annually) or $12 (billed monthly) for 1-10 members (only available to new customers), Business plan at $19 per user monthly (billed annually) or $24 (billed monthly) for 3+ members, Enterprise and Advanced Work Management with custom pricing. The Pro plan limits access to members and viewers; Business, Enterprise, and Advanced Work Management plans include unlimited guest access.
Compare to: Excel, Google Sheets for spreadsheet-familiar teams wanting more power; Airtable for database-first approach.
7. ClickUp: Best for all-in-one teams wanting multiple project views
ClickUp consolidates tasks, documents, goals, and chat into a single platform, reducing the need to switch between separate tools such as Slack for Chat and Toggl for time tracking. The interface provides multiple view options (list, board, calendar, and timeline) so team members can work in a format that matches their thinking style. Time tracking is integrated rather than requiring a third-party add-on, which simplifies billing and resource planning for teams who need to monitor hours alongside project progress.
The goal-setting features link high-level objectives to daily tasks. Mind maps are available for brainstorming and planning. The platform provides customization options for configuring the interface.
Tasks support multiple assignees for collaborative work. Recurring tasks can be set up for repetitive project stages. Universal search covers tasks, docs, and comments. ClickUp maintains ISO 27001:2022, ISO 27017:2015, ISO 27018:2019, and ISO 42001 (AI Management Systems) certifications, along with SOC 2 Type 2 compliance.
Best for:
- Teams wanting to consolidate multiple tools into one platform
- Small businesses needing comprehensive features without buying separate apps
- Remote teams requiring centralized communication and collaboration
- Organizations comfortable with customization and willing to invest setup time
Limitations: Interface can feel cluttered with so many features; performance issues reported with large datasets; automation builder requires manual setup and configuration.
Pricing: Free Forever plan (unlimited free plan members), Unlimited at $7 per user monthly (billed annually), Business at $12 per user monthly (billed annually), Enterprise with custom pricing (contact sales). Enterprise plan includes HIPAA compliance availability (with Business Associate Agreement) and data residency options (US, EU, Singapore, or APAC).
Compare to: Notion, Monday for all-in-one functionality with different interface philosophies.
Which project tracker is right for your team?
For instant setup with visual appeal: Choose Monday.com or Asana if you want pre-built templates and can start tracking progress within an hour. These tools work well if your projects follow standard patterns.
For Agile software development: Choose Jira when your team works in sprints, tracks velocity, and needs tight integration with developer tools like GitHub. The learning curve is worth it for teams who build software as their core work.
For spreadsheet-familiar teams: Choose Smartsheet when your team already thinks in rows and columns but needs to add automation. You’ll stay in the spreadsheet universe while adding project management capabilities.
For enterprise analytics and reporting: Choose Wrike when leadership needs detailed dashboards showing resource utilization and project profitability. The platform might justify its cost for larger teams who make data-driven decisions about resource allocation.
For all-in-one tool consolidation: Choose ClickUp when you want to replace multiple tools with one platform and you’re willing to invest time configuring it. The breadth of features can appeal to teams tired of switching between apps.
For a tool that fits your team’s exact workflow: Choose Bubble when off-the-shelf trackers don’t match your specific approval processes, data requirements, or access controls. AI generates a working foundation in minutes, and you can refine it visually to accommodate unique workflows that pre-built tools can’t support.
The right choice depends less on features and more on your team’s working style. A tool with every feature won’t help if your team finds it confusing. A simple tool won’t help if it forces you to work around its limitations. Start with a 30-day pilot using your most typical project. You’ll quickly see whether the tool supports or hinders your actual workflow.
Start tracking progress with the right tool for your team
Pick one tool from this list and run a 30-day pilot with a real project. Set up basic milestones, invite a small team, and see whether the tool makes status updates easier or just adds another place to check. The best tracker becomes nearly invisible. It gives you the information you need without making data entry feel like a second job.
Perfect tracking systems grow with your needs rather than being perfect from day one. Focus on capturing plan vs. actual progress and milestone status first; you can add advanced reporting and automation once the basics become habit.
When off-the-shelf tools force your team into their way of working, Bubble lets you vibe code without the code to build your own perfect project tracker. Chat with AI to generate your tracker in minutes, then edit directly when you’re ready to refine it. You can see and control every workflow in visual format, never code.
Build your custom project tracker with Bubble today.
Frequently asked questions
Should you update project status daily or weekly?
Update frequency depends on project pace: daily for fast-moving sprints, weekly for standard projects, milestone-based for longer initiatives. Automate routine updates and reserve meetings for addressing blockers.
What baseline information captures plan vs. actual progress effectively?
Capture initial scope, timeline, and budget at project start, then compare actual completion against planned milestones. This creates the foundation for measuring whether you’re ahead, on track, or behind schedule.
Which metrics matter most for tracking non-software project progress?
Focus on milestone completion rates, task cycle time, budget utilization, and active blockers. These provide clear visibility into project health without overwhelming teams with technical metrics designed for software development.
When does building a custom tracker make more sense than using existing tools?
Build custom with Bubble when your workflow requires specific approval processes, unique data capture, role-based privacy or a combination of features you can’t find in one platform. Bubble AI generates a working foundation in minutes, then you customize visually. Use off-the-shelf tools only if their templates fit your process exactly.
How do you move from spreadsheet tracking to project management software without disrupting work?
For off-the-shelf tools, import existing lists and enable basic automations gradually. With Bubble, describe your current spreadsheet workflow to the Agent. It can generate the database structure and basic workflows to get you started, then you refine visually as your team adapts.
Join building
